Hi, I started the server and cant find it in the local network. To be shure it has connection to the internet I tried the “playit” plugin, which connects the server to the internet in a different way and that worket. But as I said, the direct connection via localhost doesnt work.
Maybe check the host machine’s firewall to see if the ports are opened properly (AMP should do it automatically).
To manually kick it over: ampinstmgr updatefirewall ampinstmgr dumpfirewall
If that’s not it, it could be some internal network issue, eg if one machine is hardwired and the other is over Wifi, you might not be able to connect depending on how the network is set up.
