Connectivity Problem with Minecraft Bedrock - Minecraft Server runs, only joinable through Lan
Application Minecraft Bedrock
Made a minecraft bedrock server and got it running but cant for the life of me find a way o connect besides lan connection. please help. thank you god bless.
  • MinecraftGang01 Server setup/ testing failed / lan connection works
  • Lan connection works\ low connection ping\ still no luck
  • Try every Ip no luck/ try to reconfig no luck\ try to reinstall no luck/ help obiwan your our only hope
  • really wanna play with friends
You need to port forward so your server/machine can be reachable outside your own network. Did you port forward 19132? Did you give those outside your network your external IP to connect with?
Sadly, the only buddy i had that was gonna try is busy and everyone els is down in the dumps. but never give up right?
I will try to see what it does on their side and report back. Thank you. Much love.
