| Product | AMP ‘Proteus’ v2.8.0.8 (Mainline) |
| Virtualization | Podman |
| Application | Minecraft Bedrock |
| Module | GenericModule |
| Current State | Ready |
server-port=19136
server-portv6=19137
transport=nethernet
server-udp-ports=19186-19205
These are the settings in the server.properties and are also portforwarded in router.
Im met with “Door” error code when trying to connect to the server.
If i force Raknet with lan visibilty on i can connect externally to the server.
Im connecting directly to the server not through any tunnelservices.
I have installed AMP on a Debian server with podman.
Please help figure out where im going to wrong with the configuration.
Kind regards,
Thommy
- Added net port range for nethernet
- port forward udp range for nethernet in router
- Changed back to raknet and lan visibility to see if connection works(it does)
