Connectivity Problem with Minecraft authentication servers are down
Whenever I try to join an AMP server I created, I can’t join and I get this error message: authentication servers are down minecraft. With norm,al servers wich are not from AMP i can join.
  • Start server
  • Try to join server
  • Authentication servers are down. Please try again later, sorry!
First things:
Are you on the same local network as the AMP isntance?
Is your Minecraft console showing any entries that would suggest it failed to connect to mojang?
If you can reply with the containers network settings and your minecraft settings I can give you a hand. I’ve seen this error before but it was a one off and never came back!
I am in the same network as the server. And with (playit.gg) it does not funktionate too.
19:59:52
Starting net.minecraft.server.Main
ServerMain/INFO
19:59:56
Environment: Environment[sessionHost=https://sessionserver.mojang.com, servicesHost=https://api.minecraftservices.com, profilesHost=https://api.mojang.com, name=PROD]
Yggdrasil Key Fetcher/ERROR
19:59:56
Failed to request yggdrasil public key
Console
19:59:56
com.mojang.authlib.exceptions.MinecraftClientException: Failed to read from https://api.minecraftservices.com/publickeys due to api.minecraftservices.com
at com.mojang.authlib.minecraft.client.MinecraftClient.readInputStream(MinecraftClient.java:111) \~\[authlib-7.0.61.jar:?\]
at com.mojang.authlib.minecraft.client.MinecraftClient.get(MinecraftClient.java:56) \~\[authlib-7.0.61.jar:?\]
at com.mojang.authlib.yggdrasil.YggdrasilServicesKeyInfo.fetch(YggdrasilServicesKeyInfo.java:114) \~\[authlib-7.0.61.jar:?\]
at com.mojang.authlib.yggdrasil.YggdrasilServicesKeyInfo$1.run(YggdrasilServicesKeyInfo.java:89) \~\[authlib-7.0.61.jar:?\]
at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:572) \~\[?:?\]
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:317) \~\[?:?\]
at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) \~\[?:?\]
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1144) \~\[?:?\]
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:642) \~\[?:?\]
at java.base/java.lang.Thread.run(Thread.java:1583) \[?:?\]
Caused by: java.net.UnknownHostException: api.minecraftservices.com
at java.base/sun.nio.ch.NioSocketImpl.connect(NioSocketImpl.java:567) \~\[?:?\]
at java.base/java.net.SocksSocketImpl.connect(SocksSocketImpl.java:327) \~\[?:?\]
at java.base/java.net.Socket.connect(Socket.java:751) \~\[?:?\]
at java.base/sun.security.ssl.SSLSocketImpl.connect(SSLSocketImpl.java:304) \~\[?:?\]
at java.base/sun.net.NetworkClient.doConnect(NetworkClient.java:178) \~\[?:?\]
at java.base/sun.net.www.http.HttpClient.openServer(HttpClient.java:531) \~\[?:?\]
at java.base/sun.net.www.http.HttpClient.openServer(HttpClient.java:636) \~\[?:?\]
at java.base/sun.net.www.protocol.https.HttpsClient.<init>(HttpsClient.java:264) \~\[?:?\]
at java.base/sun.net.www.protocol.https.HttpsClient.New(HttpsClient.java:377) \~\[?:?\]
at java.base/sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.getNewHttpClient(AbstractDelegateHttpsURLConnection.java:193) \~\[?:?\]
at java.base/sun.net.www.protocol.http.HttpURLConnection.plainConnect0(HttpURLConnection.java:1297) \~\[?:?\]
at java.base/sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:1138) \~\[?:?\]
at java.base/sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:179) \~\[?:?\]
at java.base/sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1690) \~\[?:?\]
at java.base/sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1614) \~\[?:?\]
at java.base/java.net.HttpURLConnection.getResponseCode(HttpURLConnection.java:531) \~\[?:?\]
at java.base/sun.net.www.protocol.https.HttpsURLConnectionImpl.getResponseCode(HttpsURLConnectionImpl.java:307) \~\[?:?\]
at com.mojang.authlib.minecraft.client.MinecraftClient.readInputStream(MinecraftClient.java:82) \~\[authlib-7.0.61.jar:?\]
... 9 more
ServerMain/INFO
19:59:57
Loaded 1461 recipes
Loaded 1574 advancements
Server thread/INFO
19:59:57
Starting minecraft server version 1.21.10
Loading properties
Default game type: SURVIVAL
Generating keypair
Starting Minecraft server on 0.0.0.0:25565
Using epoll channel type
Preparing level “world”
19:59:58
Loading 0 persistent chunks...
Time elapsed: 11 ms
Done (0.837s)! For help, type “help”
19:59:59
Unknown or incomplete command. See below for error
tps<–[HERE]
User Authenticator #1/INFO
20:00:00
Disconnecting Jopi2009 (/192.168.178.114:53732): Authentication servers are down. Please try again later. Sorry!
User Authenticator #1/ERROR
20:00:00
Couldn't verify username because servers are unavailable
Server thread/INFO
20:00:00
Jopi2009 (/192.168.178.114:53732) lost connection: Authentication servers are down. Please try again later. Sorry!
20:00:58
Server empty for 60 seconds, pausing
