Connectivity Problem with Hytale - hytale
Application Hytale
the last error was hytale waiting for a response to peer server
Hytale] Starting authenticated flow for Binguby (953bef3c-22ef-4eac-b3d8-cab0bc25f56b) from QuicConnectionAddress{connId=8a5a08ed48403531e51c31714b3a0395312a04c9} (/49.182.101.214:46428, streamId=0)
[2026/01/18 03:12:10 INFO] [JWTValidator] Identity token validated successfully for user null (UUID: 953bef3c-22ef-4eac-b3d8-cab0bc25f56b)
[2026/01/18 03:12:10 INFO] [HandshakeHandler] Identity token validated for Binguby (UUID: 953bef3c-22ef-4eac-b3d8-cab0bc25f56b, scope: hytale:client) from QuicConnectionAddress{connId=8a5a08ed48403531e51c31714b3a0395312a04c9} (/49.182.101.214:46428, streamId=0), requesting auth grant
[2026/01/18 03:12:10 FINEST] [LoginTiming] setTimeout-auth-grant-timeout took 871us 343ns
[2026/01/18 03:12:10 INFO] [SessionServiceClient] Requesting authorization grant with identity token, aud=‘6b8efe97-bc46-4f8b-a10d-15579f00e5fa’
[2026/01/18 03:12:10 INFO] [SessionServiceClient] Successfully obtained authorization grant
[2026/01/18 03:12:10 INFO] [HandshakeHandler] Sending AuthGrant to QuicConnectionAddress{connId=8a5a08ed48403531e51c31714b3a0395312a04c9} (/49.182.101.214:46428, streamId=0) (with server identity: true)
[2026/01/18 03:12:10 FINEST] [LoginTiming] setTimeout-auth-token-timeout took 340ms 140us 768ns
13:12:12
[2026/01/18 03:12:12   INFO]               [HandshakeHandler] Received AuthToken from QuicConnectionAddress{connId=8a5a08ed48403531e51c31714b3a0395312a04c9} (/49.182.101.214:46428, streamId=0), validating JWT (mTLS cert present: true, server auth grant: true)
[2026/01/18 03:12:12 INFO] [CertificateUtil] Certificate binding validated successfully
[2026/01/18 03:12:12 INFO] [JWTValidator] JWT validated successfully for user Binguby (UUID: 953bef3c-22ef-4eac-b3d8-cab0bc25f56b)
[2026/01/18 03:12:12 FINEST] [LoginTiming] setTimeout-server-token-exchange-timeout took 1sec 178ms 441us 54ns
[2026/01/18 03:12:12 INFO] [SessionServiceClient] Exchanging authorization grant for access token
[2026/01/18 03:12:12 INFO] [SessionServiceClient] Successfully obtained access token
[2026/01/18 03:12:12 INFO] [HandshakeHandler] Sending ServerAuthToken to QuicConnectionAddress{connId=8a5a08ed48403531e51c31714b3a0395312a04c9} (/49.182.101.214:46428, streamId=0) (with password challenge: false)
[2026/01/18 03:12:12 INFO] [HandshakeHandler] Mutual authentication complete for Binguby (953bef3c-22ef-4eac-b3d8-cab0bc25f56b) from QuicConnectionAddress{connId=8a5a08ed48403531e51c31714b3a0395312a04c9} (/49.182.101.214:46428, streamId=0)
[2026/01/18 03:12:12 FINE] [LoginTiming] Authenticated took 268ms 913us 303ns
[2026/01/18 03:12:12 INFO] [PasswordPacketHandler] Connection complete for Binguby (953bef3c-22ef-4eac-b3d8-cab0bc25f56b), transitioning to setup
[2026/01/18 03:12:12 FINEST] [LoginTiming] setTimeout-send-world-settings took 162us 593ns
[2026/01/18 03:12:12 FINE] [LoginTiming] Load Player Config took 66us 964ns
[2026/01/18 03:12:12 FINEST] [LoginTiming] setTimeout-receive-assets-request took 19ms 512us 566ns
13:12:42
[2026/01/18 03:12:42   INFO]                         [Hytale] {Setup(null (null, streamId=0)), Binguby, 953bef3c-22ef-4eac-b3d8-cab0bc25f56b, SECURE} was closed.
[2026/01/18 03:12:42 INFO] [QUICTransport] Connection closed: QuicheQuicConnectionStats[recv=25, sent=129, lost=0, retrans=11, sentBytes=134410, recvBytes=12105, lostBytes=0, streamRetransBytes=7920, pathsCount=1]
