Connectivity Problem with Hytale - Hytale server connection using playit.gg not working
Application Hytale
hytale server is connected via tunneling using playit.gg, when using the local ip address I can connect to server but using the playit.gg it does not. This worked fine yesterday and I was able to connect through the playit.gg tunnel, now it is now working.
  • I have restarted, updated, shutdown, backed up the instance
  • I changed the tunneling to be on a different port
  • I have tested this on local versus tunnelled address and it works on local
