Connectivity Problem with Enshrouded - GamePort 15777 [Closed] - Server cannot be connected to
Operating System Linux - Ubuntu 22
Application Enshrouded
Server does not show up in list & no connection via adress or IP possible.
Checked on Server [Ubuntu22] - on FW ports are open & mapped, but ampinstmgr ports lists
GamePort 15777 as [Closed] - How can I change this?
ampinstmgr documentation is a bit lacking
  • Created Enshrouded server in docker via web interface
  • tried to connect to server via server list, IP and adress - no success
  • Checked server firewall UFW and the required ports 15777 and 15778 are open for udp and tcp
FWIW I am also running into this issue.
firefox_mWV0CmDNOn
Server looks to be up and running fine.
[Session] 'HostOnline' (up)!
[Session] finished transition from 'Lobby' to 'Host_Online' (current='Host_Online')!
I am also showing red for the game port, but it is up and able to connect to the server just fine.
here the same, ports showing red , but i can connect.
Yep, I am also able to connect.
Tip for anyone trying to add your server via the server browser, I had to use the query port (not the game port) to get it to add properly.
