Field | Value |
Operating System | Windows - Windows Server 2022 on x86_64 |
Product | AMP ‘Phobos’ v2.6.0.6 (Mainline) |
Virtualization | Xen |
Application | DayZ (Stable) |
Module | GenericModule |
Running in Container | No |
Current State | Ready |
I can’t connect to the Server, it is shown in the Serverlist but every time I try to connect the loading bar stucks at ~80% and doesn’t move any further. (waited for 10+ Minutes)
The console doesn’t even show my connection attempt and I don’t know if or where are logs who might help finding the problem.
Machine is a fresh installed Windows Server 2022, running as a VM (Proxmox) on a dedicated Server at Hetzner - Germany.
Someone with the exact same error already opened a Thread on Discord, sadly w/o any answer since November 18th.
- Disable all Firewalls (testing)
- Install new DayZ Server
- Try to connect
