| Product | AMP ‘Phobos’ v2.6.3.0 (Mainline) |
| Virtualization | Docker |
| Application | DayZ (Stable) |
| Module | GenericModule |
| Current State | Stopped |
After creating the Dayz stable instance i forward all required ports. Everything is green for listening. When i try to join through DayZ server browser it says unable to join, i also cant find it the the server browser. When i try to add it to my favorites in steam it says didnt find any servers at that address. Ill also add i have a Minecraft and Valheim server running with no problems
- Create DayZ instance
- Forward ports
- attempt to join
I fixed it the problem is not AMP’s fault dayZ just sucks. You need to paste this link in your browser to get the initial connection. replace ip with your ip. i couldnt get it to work with a domain so swap em if one doesnt work
steam://run/221100//+connect :2302 -noLauncher -skipIntro -noSplash
