Field | Value |
Product | AMP ‘Phobos’ v2.6.0.6 (Mainline) |
Virtualization | Docker |
Application | DayZ (Stable) |
Module | GenericModule |
Running in Container | Yes |
Current State | Ready |
Hello, I’ve configured my server. I don’t know the IP address of my Dayz server, so I can’t try to connect to it from the launcher. I see in the server management that the IP is 0.0.0.0 with port 2302. I don’t know where to change this IP. I’ve tried to find my server using the IP address of my VPS and using port 2302, but that doesn’t work either.
- I configure the server (mpmission, mods)
- I change the starter parameters (load mod and template for the map)
- I don’t do anything for the IP but I dont know where I’m suppose to do that
-----> UPDATE : Problem solved. I restarted the VPS. I also changed the Steam Querry port.
