If the server is started and can be accessed on LAN then it is a port forward issue (or ports are blocked by your ISP). Randomly changing binding and adding ports to the instance won’t change anything
I’m not sure if anything else the end point is 0.0.0.0:2302 if that is anything I’m very new to using game panels as I would normal just use the old way with out them.
so followed them and managed to get this to work on my windows but now I’ve actual moved onto my server running Linux ubuntu server done all the same things but for some reason nothing is now showing at all now.
all is ported router side
also the is the experimental version of dayz
