| Product | AMP ‘Callisto’ v2.5.0.0 (Mainline) |
| Virtualization | VMware |
| Application | Counter-Strike 2 |
| Module | GenericModule |
| Running in Container | No |
| Current State | Ready |
When the server doesnt have a password there is no problem whatsoever to connect to it.
When adding a password and pressing connect in steam, a window flashes by and I end up in the connect menu again.
I can also not se the server listed as a server with password.
- Set up server with standard settings
- Verified correct server function and connectivity without having password
- Added password to serverconfig
- Verified that problem exists only when password is used in config
- Removed password from config again and tested that connecting to server works
