| Product | AMP ‘Decadeus’ v2.4.8.0 (Mainline) |
| Virtualization | Docker |
| Application | Counter-Strike 2 |
| Module | GenericModule |
| Current State | Ready |
I followed this tutorial:
When I copy the ip endpoint with the port, open the console in cs and run connect : it just cant connect. I donno if I did anything wrong during the process.
My current endpoint is 0.0.0.0. That’s strange isn’t it? Shouldn’t it be something full of numbers?
- Copied the endpoint
- opened the cs console
- typed connect ip:port. However it never works
