Connectivity Problem with Counter-Strike 1.6 - Cannot access to SFTP via FileZilla
Product AMP ‘Phobos’ v2.6.0.0 (Mainline)
Application Counter-Strike 1.6
I cannot access to SFTP. Is it possible for you to make a check?
  • Set up my server
  • Checked the login informations
  • Entered the login infomations as written
Make sure the port is accessible in the firewall, and if you’re using 2FA, make sure to append the code to the end of your password.
