| Field |
Value |
| Operating System |
| Product |
AMP ‘Phobos’ v2.6.0.10 (Mainline) |
| Virtualization |
Docker |
| Application |
Astroneer |
| Module |
GenericModule |
| Running in Container |
Yes |
| Current State |
Ready |
Create Instance, all looks good, Ports are listening, Ingame Server show Offline for LAN-IP and external IP
- Create Instance, Ports are Listening
- create Router Portforwarding
- Ingame show Offline for LAN and External IP
There is a UI box under Configuration>Astroneer that explains the configuration changes you need to make on the client side
And the Astroneer client will only connect using the public IP
Hi,
did you mean this?
Linux Server Configuration
WARNING: Running Astroneer on Linux requires encryption to be disabled on both server and clients. USE AT YOUR OWN RISK. To disable encryption on a client, add net.AllowEncryption=False under the [SystemSettings] header in %LocalAppData%\Astro\Saved\Config\WindowsNoEditor\Engine.ini
Hi,
this was first in the file:
[Core.System]
Paths=…/…/…/Engine/Content
Paths=%GAMEDIR%Content
Paths=…/…/…/Engine/Plugins/Wwise/Content
Paths=…/…/…/Astro/Plugins/Runtime/Analytics/AstroPfAnalytics/Content
Paths=…/…/…/Astro/Plugins/AstroTests/Content
Paths=…/…/…/Astro/Intermediate/Plugins/Terrain2CompiledAssets/Windows/Game/Content
Paths=…/…/…/Engine/Plugins/2D/Paper2D/Content
Paths=…/…/…/Engine/Plugins/Developer/AnimationSharing/Content
Paths=…/…/…/Engine/Plugins/Editor/CryptoKeys/Content
Paths=…/…/…/Engine/Plugins/Editor/CurveEditorTools/Content
Paths=…/…/…/Engine/Plugins/Enterprise/DatasmithContent/Content
Paths=…/…/…/Engine/Plugins/Experimental/AutomationUtils/Content
Paths=…/…/…/Engine/Plugins/Media/MediaCompositing/Content
Then I add:
[SystemSettings]
and now the this is added too from the system:
[WindowsApplication.Accessibility]
StickyKeysHotkey=True
ToggleKeysHotkey=True
FilterKeysHotkey=True
StickyKeysConfirmation=True
ToggleKeysConfirmation=True
FilterKeysConfirmation=True
In the description below stand I should change the encryption on both side.
Ich found on AMP-Side under
Astroneer/File Manager/ Astro/Saved/Config/WindowsServer/Engine.ini
There I also add this:
[SystemSettings]
But afer restart it is away.
AMP handles the server. Just deal with client
