Connectivity Problem with Astroneer - Astroneer dedicated server fails to open UDP port 7777
Virtualization Podman
Application Astroneer
Running the Astroneer dedicated server (App ID 728470) inside an AMP instance (version 2.8.0.4) on a Debian Linux host running in a container/Podman environment. After switching the Proton version to GE-Proton9-1 to resolve initial startup errors, the server process successfully launches and the RCON/console port (1234 TCP) changes to a listening state. However, whether the ZeroTier virtual mesh VPN is active or disabled, and despite waiting over 5 minutes for the Unreal Engine process to initialize, the game port (7777 UDP) persistently fails to open or show as listening, preventing any connection to the server.
  • Installed AMP version 2.8.0.4 on Debian Linux running inside a container environment.
  • Deployed the Astroneer dedicated server (App ID 728470) via SteamCMD in AMP.
  • Changed the Proton version to GE-Proton9-1 in AMP settings to allow the server binary to start successfully.
  • Verified that the server starts and listens on the RCON/console port (1234 TCP), then waited for the Unreal Engine process to open the game port (7777 UDP).
  • After 5 minutes port 7777 still does not listen.
Not sure on this, but found another post on Astroneer where Greelan noted it was working with GE-Proton10-34. Might try that.
Thanks for the suggestion! I actually tried that version, but the server wouldn’t even start with GE-Proton10-34. The only version I’ve been able to get the server to boot up with is GE-Proton9-1.
