| Product | AMP ‘Deimos’ v2.7.2.4 (Mainline) |
| Virtualization | Podman |
| Application | ARK: Survival Evolved |
| Module | GenericModule |
| Current State | Ready |
Brand new install of AMP on brand new VM (debian). When starting instance it says RCON port connection is failing.
I ran iptables -L -n and chain input (policy accept) is showing all the appropriate ports listed with both udp and tcp.
As an add, I tried a different server type, satisfactory, and having a similar issue. Where ports are said they are open but I cannot connect on LAN.
- Installed TailScale
- Installed AMP (had to turn off IPv6 in order to get download to work properly)
- Created Instance of Ark Survival Evolved
