| Product | AMP ‘Phobos’ v2.6.0.10 (Mainline) |
| Virtualization | Docker |
| Application | ARK: Survival Evolved |
| Module | GenericModule |
| Current State | Failed |
ASE server not showing up outside of LAN, I’ve followed all the troubleshooting I can find and nothing. Firewall has the ports set up right, “ampinstmgr ports” lists them as listening, websites like https://canyouseeme.org/ show the ports as closed. Server launches just fine and can be joined via LAN.
I set up a Terraira server at the same time and it is working perfectly, as well as I had a functioning and connectable-to ASE server running last year.
- Create an ASE Server
- Forward required ports
- Start server and attempt to join via non-LAN
