| Field |
Value |
| Operating System |
Linux - Ubuntu 24.04.3 on x86_64 |
| Product |
AMP ‘Phobos’ v2.6.2.6 (Mainline) |
| Virtualization |
None |
| Application |
ARK: Survival Evolved |
| Module |
GenericModule |
| Running in Container |
No |
| Current State |
Ready |
i have problems with joining the server
when i try joining through steam server it says “network failure message, unable to query server info for invite”
i have tried adding it to my favorites in the server popup and joining through the serverbrowser ingame but that didnt help either
also searching the name of the server doesnt show it in the server browser
- start server
- adds server to favorite in steam server menu
- atempt to join
- it opens ark but it doesnt join
Did you forward the 3 server ports?
the ports i have forwarded are “2226tcp, 27020tcp, 7777upd, 27015upd, 7778upd”
i also cannot connect through lan
the firewall has already excluded all these ports so that is also not the problem
idk what else could be the problem.
In steam favourites, you need to add the server via the query port
This is covered in the guide in this forum for ASE
BTW, don’t forward the SFTP port or RCON port, unless you really need access to them externally
when i do that it says “failure unable to connect to server, app id specified by server is invalid”
and not much more changes
Then you very likely have networking issues
Are you trying to add the server via public IP, or local IP
sorry for the late response.
i have tried both, inside and outside the lan with and without the public ip
