Connectivity Problem with ARK: Survival Ascended - Only one instance showing
Operating System Linux - Ubuntu 22.04.5 on x86_64
Application ARK: Survival Ascended
My IP recently changed/updated itself. All instances were working pre-update. I did add 2 more instances recently and 1 of the new ones is the one that is actually showing. I checked and compared all settings between the new one and all of my other instances. I made sure to check all of the toggles in the in-game browser to make sure a filter was causing the instance to not show. Only 1 of my 8 instances actually showed up in my in-game browser. I tried to manually connect to the instances as well to no avail. Thank you for any help/guidance you can bring!
  • Started an instance
  • Opened game (ARK: SA)
  • Navigated to server browser
  • Waited 2-5 min. Didn’t see the server populating
  • Closed that instance and tried the next one
  • Repeated these steps through all 8 instances.
