Field | Value |
Operating System | Windows - Windows 10 Pro on x86_64 |
Product | AMP ‘Phobos’ v2.6.0.2 (Mainline) |
Virtualization | None |
Application | ARK: Survival Ascended |
Module | GenericModule |
Running in Container | No |
Current State | Ready |
Hello.
I have installed the server as normal. The computer is a Windows 10 PRO which is only used for AMP.
The server should actually only be used locally in the network. no connection possible internally either.
When I connect via steam:// I get the message that the server connection is not possible because the ANW ID specified by the server is invalid.
I have installed another server (Rust) that works and a connection is possible.
- CHeck Firewall on Server an Firewall. All Free
- netstat -ano on Server. Server is Listening on 0.0.0.0 :7777
- Deactivate Firewall on Server an apply any to Server Ruleon Firewall.
