| Product | AMP ‘Phobos’ v2.6.0.12 (Mainline) |
| Virtualization | Docker |
| Application | ARK: Survival Ascended |
| Module | GenericModule |
| Current State | Ready |
5 servers in a cluster are started and running, however I cannot access 3 of them via the game, I have noticed this in the past when the servers are not on the current version howerver multiple tries updating have not worked and the logs say that they are up to date. same steps on the working servers without issue. Log files for working and non working show no differences
updated amp
stopped and updated the 3 instances
start the instance
I’ve had a break through on further investigation. a few things i noticed on all 3 servers. -
The game.ini had been set to blank
The gameusersettings.ini had been reset and was not what was originally set by me (compared to original file I keep myself)
password was set in the config but was not applying had to set this to blank, let it save and then re-add it.
So the servers where actually appearing, just not as part of the cluster and with no password set. strange that an update would cause this.
hopefully the above helps someone else if they run into this issue
