After clicking start, it takes a while for the server to start.
After the server has started, Application Status says: Running.
When the server starts, the red dots in Network change color to green dots.
The server is not listed in the game.
Changed the IP address in Network to that of the PC
27015 TCP and UDP
7777 to 7787 TCP
8885 to 8895 TCP
27020 to 27030 TCP
When I use Ark Server Manager to host an Ark Survival Evolved server, it shows up in the Unofficial server list.
When I host the Ark Survival Evolved server via AMP,
then it is only displayed to me in LAN.
No remote targets have yet been set up.
This ADS installation has been setup as a controller, which means it cannot create instances by itself. You must create a Target ADS instance and register it with this controller before creating instances.
I’ll try again tomorrow.
Update 01:
The problem is now solved.
I deleted the program and deleted the Standard Database and reinstalled it.
Now I can move on to my primary problem.
I also tried the ASA Dedicated Manager and I can get the ASA server in there
Game not listed either
