Connectivity Problem with Application Deployment - Unable to connect to server when it's connected to Ethernet
Operating System Linux - Ubuntu 26.04 on x86_64
Product AMP ‘Deimos’ v2.7.2.8 (Mainline)
OS Linux
Platform Ubuntu 26.04
System Type x86_64
Hardware Platform Dell Inc. 0WMJ54
CPU Model Intel(R) Core™ i5-4670 CPU @ 3.40GHz
CPU Layout 1S/4C/4T
Installed RAM 15395
Network Mode Standard
Loaded Plugins FileManagerPlugin, EmailSenderPlugin, WebRequestPlugin, WebhookPlugin, LocalFileBackupPlugin, CommonCorePlugin, AnalyticsPlugin, StorePlugin
Application Name AMP
Application Version 2.7.2.8
Codename Deimos
Tools Version 2.7.2.8
Release Stream Mainline
Build Spec Release
Build Date 08/06/2026 00:16
InstanceID 5cc16b67-399e-49c7-aa75-0e0aa78a99c6
Last Executable
Last Arguments
Last Process ID 88653
I have been running a server for Vintage Story, it works as intended when the server is connected to Wifi outside of occasional connection issues which I connected to ethernet to solve, however I can connect via local IP now but no one including myself can connect via public IP which I was able to do on Wifi.
I have opened ports 42420TCP/UDP - 2225/TCP - 8080 TCP/UDP - 8081 TCP/UDP (unsure if the last 3 are necessary) I reset UFW and Verified the ports are open.
I’ve messed with various settings in the web manager can’t remember all that have been changed, I’ve been putsing all week. I’m thinking the Local IP change from Wifi to Ethernet may be causing it but I haven’t found any way to verify or fix that.
  • Install and set up AMP using Wifi
  • Connect server PC to Ethernet
  • Attempt to connect via public IP
