Connectivity Problem with Application Deployment - the server port show red color 27015
Operating System Linux - CentOS Linux 8 on x86_64
Virtualization HyperV
  • the server port show red color 27015
This is an invalid report. No reproduction steps given, no desciption that would tell me what the problem is. My guess is that you intended to open this in a specific instance but did so at the ADS level instead.
Please send any guide that show step by step how to create the server , because of it’s not understood.
can you send please?
Create a new instance and select the application you want to run. Read carefully if there are any extra steps mentioned. They would be linked to an article here in discourse. In either case you need to manage the instance first. Follow the extra steps if necessary. Hit update. Hit start. The application is running.
If you encounter any problems, create a post here with enough information or ask at discord.
still not understood your answer.
I have VM that I manage it and have 1 public ip address and linux machine with your application that runnuing in Standalone mode
the servers in instance show green window’ but once I enter it and see the ports , its show in red color,
the ports in firewall also open
please assist
  1. Click “Update” (the orange box)
Then, when that is finished:
  1. Click “Start” (the green box)
still doesn’t work
all port 27015-27020 TCP and UDP opened
Which game are we talking about? How long did you wait for the server to start? Share the output from the console.
Iirc, there is a bug with UDP ports always showing as closed even if the server already listens on the port. Did you try to connect to the server?
cs 1.6
cs 2
yes I tried to login to the server and not working.
output from console:
13:49:17
AMP is up to date.
:admin
13:50:41
Managed remote instance s1-Az-SpEeDMaX101 at http://127.0.0.1:8082/
Authentication token for admin requested by ManageInstance on behalf of admin
13:57:25
13:57:36
13:57:58
f0ad030ddeb4b22c3b408a84baec580de21a3bb8d924a6a9f249a2198688ac15
Managed remote instance server101 at http://10.1.0.4:8084/
13:57:58
LIM - Failure to make API call to server101: Connection refused
:admin
13:58:09
13:58:31
Upgrading instance server101
13:58:32
Using default tag: latest
13:58:34
latest: Pulling from cubecoders/ampbase
Digest: sha256:e836dc28133d1386e6b4f1c81b6767945a4909eef095b87ed480c9f371978c0a
Status: Image is up to date for cubecoders/ampbase:latest
docker.io/cubecoders/ampbase:latest
13:58:57
another cs 1.6 server that try to run in another port 27016 got this error:
This task could not be completed: Updating… - Updating Counter-Strike 1.6 Dedicated Server - State: 3.
Failed to request AppInfo update, not online or not logged in to Steam.
Are you running all of AMP in Docker?
I don’t know
How can I check it?
