| Operating System | Windows - Windows 10 Pro on x86_64 |
| Product | AMPService ‘Decadeus’ v2.4.6.6 (Mainline) |
| Virtualization | None |
| Module | ADSModule |
| Running in Container | No |
So answer when opening the server manager
Failed to login to remote instance. AMP tried to login to auth server at http://localhost:8080/ but it could not be reached. Please make sure that the AuthServerURL setting in AMPConfig.conf for this instance is valid and addresses your ADS controller/standalone instance. Unexpected character encountered while parsing value: <. Path ‘’, line 0, position 0.
Login server unreachable. Verify that the auth server URL in this instances config file is valid. This is the ‘Login.AuthServerURL’ line in AMPConfig.conf for this instance.
- Resatart AMP
- Server re-created
- Security setting changed
