Connectivity Problem with Application Deployment - cant make server or im doing it wrong
Virtualization QEMU_KVM
I made a minecraft server i got the domain to make it fast to connect i dont know what to do to get the server name and the address and the port or how to link the cdowd.net to the minecraft server
  • I tried to restart the server
  • I got a domain name so i can use that for the server name but its not connected to the Minecraft server
  • I tried going to the support section to find out what to to do add the doamin name but cant find it
You would need to do that in your DNS settings for your domain, it is not something you can do inside the AMP panel. This is also the forum for AMP, only Hostinger’s support can help you with any DNS configuration problems you may have.
This is a good example that generally explains how to set up a domain for Minecraft:
https://shockbyte.com/help/knowledgebase/articles/setting-up-a-custom-server-ip-domain-or-subdomain
