I am trying to get a paper server set up so I can run my mods and host my own server which is currently being hosted elsewhere but the software seems to fail if I want to do anything outside of the default config it sets when the instance is created
Won’t let me upload the log since it’s an unauthorized file type but here it is
[14:10:45] [Core Info] : Starting AMP version 2.4.8.0 (Decadeus), built 29/01/2024 18:40
[14:10:45] [Core Info] : Stream: Mainline / Release - built by CUBECODERS/buildbot on CCL-DEV
[14:10:46] [Logger Info] : Purging old audit logs (this may take a moment)…
[14:10:46] [Core Warning] : Current time zone is set to EST - It is recommended you switch to UTC+0 to avoid time-zone related issues
[14:10:46] [Core Info] : OS: Linux / x86_64
[14:10:46] [Core Info] : CPU: 11th Gen Intel(R) Core™ i5-1135G7 @ 2.40GHz (4C/8T)
[14:10:46] [Core Info] : RAM: 15646MB
[14:10:46] [Core Info] : AMP Instance ID: ab132d0a-2c3c-4335-b435-8c127ed57680
[14:10:46] [Loader Info] : Loaded MinecraftModule version 1.0.0.3 by CubeCoders Limited
[14:10:46] [Core Info] : Metrics publishing is enabled at udp://localhost:12820.
[14:10:46] [Loader Info] : Loaded FileManagerPlugin by CubeCoders Limited
[14:10:46] [Loader Info] : Loaded EmailSenderPlugin by CubeCoders Limited
[14:10:46] [Loader Info] : Loaded WebRequestPlugin by CubeCoders Limited
[14:10:46] [Loader Info] : Loaded LocalFileBackupPlugin by CubeCoders Limited
[14:10:46] [Loader Info] : Loaded CommonCorePlugin by CubeCoders Limited
[14:10:46] [Core Info] : Licence Present: AMP Advanced Edition
[14:10:47] [FileManager Notice] : Using keypair with fingerprint omp+CiAVg1R9c3d1rmRKnhnQeP2xwqtS6fYhRPjwhnA=
[14:10:47] [FileManager Info] : SFTP Server started on 0.0.0.0:2224
[14:10:47] [Webserver Info] : Websockets are enabled.
[14:10:47] [Webserver Info] : Webserver started on http://127.0.0.1:8081
[14:10:47] [Logger Info] : RouterTimer@10Hz with 2 jobs started
[14:10:47] [Core Info] : Checking for AMP updates…
[14:10:47] [Minecraft Warning] : Unable to get Bedrock version data from https://www.minecraft.net/en-us/download/server/bedrock: Match not found.
[14:10:47] [Minecraft Info] : Trying first Bedrock info fallback…
[14:10:47] [Minecraft Info] : Modpack cache is up-to-date.
[14:10:47] [Core Info] : AMP is up to date.
[14:10:52] [Minecraft Info] : Latest Bedrock version: 1.20.62.02
[14:10:52] [Core Activity] : Authentication attempt for user admin from 127.0.0.1
[14:10:52] [Core Activity] : Authentication success
not sure why It’s talking about bedrock… it’s a java instance and paper is also java
It would appear the issue was to do with the AMP install itself, re-installing AMP and following the exact same steps worked this time, please close ticket
