Connectivity Problem with Application Deployment - Cannot connect to running Minecraft server
Virtualization QEMU_KVM
This is with Minecraft bedrock edition. After adding the server IP and port to Minecraft, it is able to display the server’s player count and ping, but attempting to actually connect to it fails. I believe I’m running the latest version of Minecraft on my own PC (v1.20.50).
Below you will find the server information. Let me know if you need any more details.
OS Linux
Platform Debian GNU/Linux 11
System Type x86_64
CPU Model AMD EPYC 7543P 32-Core Processor
CPU Layout 1S/2C/2T
Installed RAM 7959
Loaded Plugins FileManagerPlugin, EmailSenderPlugin, WebRequestPlugin, LocalFileBackupPlugin, CommonCorePlugin
Application Name AMP
Application Version 2.4.6.10
Codename Decadeus
Tools Version 2.4.6.4
Release Stream Mainline
Build Spec Release
Build Date 06/12/2023 17:17
InstanceID de9590fd-0272-4467-b49f-295f27ae9770
Last Executable /usr/bin/tmux
Last Arguments -f /dev/null new-session -s “AMP_FantasyIsland01” -d "cd ‘/home/amp/.ampdata/instances/FantasyIsland01’; /home/amp/.ampdata/instances/FantasyIsland01/AMP_Linux_x86_64 +Core.Webserver.Port “8081” +Core.Webserver.IPBinding “93.188.167.239” +Core.AMP.InstanceID “----” +FileManagerPlugin.SFTP.SFTPPortNumber “2224” +MinecraftModule.Minecraft.PortNumber “19132"”
Last Process ID 67090
  • Start the server instance.
  • Update the instance with the “Update” button.
  • After the update, confirm that the instance is marked as “Running” in the Hostinger Game Panel.
  • Enter server IP and port in Minecraft as a new server.
  • Minecraft attempts to connect, but fails.
We are not Hostinger, you may want to talk to their support.
You may want to see if this guide (then update after following those steps) helps, otherwise you can download the Bedrock server binary from microsoft and upload it over SFTP.
