Connection Issues
OS Name/Version: Ubuntu 24.04.2 LTS
Product Name/Version: AMP Release “Phobos”
v2.6.1.2
Hi, I have a problem with my vrising server connection, my friends can’t use either the primary endpoint connection or the steam connect in the instance. But they can use if I replace it with my external ip and the same port. I did the port forwarding and checked each port and the firewall if there running properly
Step 1: Start a new instance of Vrising in a docker container
Step 2: tried both primary endpoint and steam connect, doesn’t work
Step 3: used external ip plus either port and it works
Actions taken to resolve so far: I just replaced the Ip address with an external instead of the one provided.
Yeah, when connecting externally they’ll need to use the public IP.
AMP autofills that info from the URL you’re using to connect to AMP.
oh okay okay, thanks again ^^
