Configuration with VEIN - Vein
Application VEIN
When i update the Game.ini file and hit save and reload the server it is not saving and keeps going back to default
  • open game.ini
  • edit game.ini
  • save game.ini
Manage Game.ini via Configuration>VEIN
I am going to the file through AMP and editing it but as soon as i start the server it resets to default. All i am doing is adding a Password on it and saving the file then restarting the server. As soon as the server starts i look and the Game.ini file is default
I am going through the Vein folder to folder named 2131400 to Vein to saved to config to windows server and there is the game.ini file i am editing
When i start the server not using AMP and use just steam.CMD it works fine
That’s not what I said
You need to manage it via the AMP UI
Manage the instance, then go to the Configuration menu, then the VEIN submenu
Don’t edit the file directly
Got it thank you, my bad first time using AMP. Just got it a couple hours ago .
