Configuration with Valheim - does not add to the firewall
Operating System Windows - Windows Server 2022 on x86_64
Product AMP ‘Callisto’ v2.5.0.12 (Mainline)
Virtualization HyperV
Application Valheim
I created an instance as usual, I try to connect to the server but it is not accessible… I decided to check the firewall rules and it turned out that it did not create rules.
In the settings, the option Exclude rule creation is disabled.
    1. Create Instance (Valheim)
    1. Update Instance
    1. Start Instance
