Configuration with Squad Dedicated Server - Squad Admin Configuration Not Working
Product AMP ‘Callisto’ v2.5.0.12 (Mainline)
Application Squad Dedicated Server
We copied the exact same server config files from a different server, changing only necessary values like RCON IPs. So we know this Admin.cfg is a valid file, so it must not be being read somehow. Could you point me in the right direction?
Is it possible that we can only configure our server using the config files rather than the config panel? We would be much more comfortable with this, as there seems to be some conflictions between the files and your panels.
  • Edit Admins.cfg to include your Steam64 as superadmin
  • Join our Squad server ([ACE] Test) in the custom browser
  • Enter server and try to enter admin cam (shift+P), use commands (~ + AdminChangeLayer). These commands do not work due to invalid access levels, which should be granted from being superadmin.
