Configuration with Seven Days To Die - Darkness Falls Mod
Operating System Windows - Windows 11 Home on x86_64
Product AMP ‘Decadeus’ v2.4.6.0 (Mainline)
Application Seven Days To Die
Or if any one could give any tips on setup for darkness falls that would be amazing.
Hi, Installed darkness falls on a new instance which is running but when i try to connect if fails and i get the below in the console, any help you could give would be great - sorry if its something simple im a little new to this.
2023-08-16T10:40:05 3418.634 INF [Auth] Crossplay authorization successful: EntityID=-1, PltfmId=‘Steam_76561199024087719’, CrossId=‘EOS_00023af5253d441a9f3a31fcdbbd4a5b’, OwnerID=‘Steam_76561199024087719’, PlayerName=‘swalters’, ClientNumber=‘2’
2023-08-16T10:40:05 3418.643 INF Allowing player with id EOS_00023af5253d441a9f3a31fcdbbd4a5b
2023-08-16T10:40:05 3418.784 INF RequestToEnterGame: EOS_00023af5253d441a9f3a31fcdbbd4a5b/swalters
2023-08-16T10:40:05 3418.784 ERR Task_CommWriterSteam (cl=Steam_76561199024087719, ch=0):
2023-08-16T10:40:05 3418.784 EXC Object reference not set to an instance of an object
at NetPackageIdMapping.write (PooledBinaryWriter _writer) [0x00013] in :0
at NetConnectionSteam.Task_CommWriter (ThreadManager+ThreadInfo _threadInfo) [0x00082] in :0
UnityEngine.StackTraceUtility:ExtractStringFromException(Object)
Log:Exception(Exception)
NetConnectionSteam:Task_CommWriter(ThreadInfo)
ThreadManager:myThreadInvoke(Object)
System.Threading.ThreadHelper:ThreadStart_Context(Object)
System.Threading.ExecutionContext:RunInternal(ExecutionContext, ContextCallback, Object, Boolean)
System.Threading.ExecutionContext:Run(ExecutionContext, ContextCallback, Object, Boolean)
System.Threading.ExecutionContext:Run(ExecutionContext, ContextCallback, Object)
System.Threading.ThreadHelper:ThreadStart(Object)
2023-08-16T10:40:05 3418.784 INF Exited thread NCSteam_Writer_Steam_76561199024087719_0
2023-08-16T10:40:05 3418.784 INF Exited thread NCSteam_Reader_Steam_76561199024087719_0
2023-08-16T10:40:05 3418.784 WRN DynamicMusic: -1 was not in Bloodmoon state cache on disconnect
2023-08-16T10:40:05 3418.784 WRN Client disconnected from dy mesh: Id: -1 Total: 0
2023-08-16T10:40:05 3418.784 WRN Client disconnect complete for -1 Total: 0
2023-08-16T10:40:05 3418.784 INF Player disconnected: EntityID=-1, PltfmId=‘Steam_76561199024087719’, CrossId=‘EOS_00023af5253d441a9f3a31fcdbbd4a5b’, OwnerID=‘Steam_76561199024087719’, PlayerName=‘swalters’, ClientNumber=‘2’
2023-08-16T10:40:05 3418.784 INF Exited thread NCSteam_Reader_Steam_76561199024087719_1
2023-08-16T10:40:05 3418.784 INF Exited thread NCSteam_Writer_Steam_76561199024087719_1
2023-08-16T10:40:05 3418.984 INF [Steamworks.NET] NET: Dropping client: 76561199024087719
  • New instance
  • Update and install
  • Restart
