Configuration with Seven Days To Die - activate health bar
Virtualization Podman
Application Seven Days To Die
I can’t figure out how you turning it on so you can see the health of the zombies.
after update you can do that in sigal player before you start the game.
  • google and manual edit
With the new version of 7dtd there are a lot of options now that aren’t in the Amp template. You may have to set up the game on a computer directly and then copy the files over to Amp to get them implemented.
I found out you neded to use Sandbox Code in det game and coppy that in to server.
Under Gameplay and Sandbox Code, code will look samthing like this. AAAJABJAEJARDASGENCGHFAMLANBBJCBKCBLCBNBCOHCPJETK
