Configuration with Rust Dedicated Server - Admin command or items spawned being publicly broadcasted. Help!
Application Rust Dedicated Server
Module RustModule
I’m using AMP Panel for my Rust VPS hosted with Hostinger. Every admin command or item spawn I use is being publicly broadcasted in chat to all my players, and there’s no visible way for me to disable this from AMP Panel directly.
Can you please disable admin action logging/broadcasting internally on my Rust instance?
Thank you.
  • Just using the rust console, or the amp panel console
  • Tried to spawn in items
  • Broadcasted commands in console
