Configuration with Palworld - Custom PalWorld Settings Not Applying (PalWorldSettings.ini)
Application Palworld
Hi Hostinger Support,
I’m currently hosting a Palworld server with you and trying to apply custom settings by editing Pal/Saved/Config/WindowsServer/PalWorldSettings.ini. However, any changes I make (e.g., time speed, difficulty) are not taking effect when I restart the server — the game keeps reverting to default settings.
I’ve also tried pointing the GameUserSettings.ini to the custom config by adding:
ServerCustomSettingsPath=PalWorldSettings
But the issue still persists.
Can you please confirm if your system is overriding the PalWorldSettings.ini file or using a different startup method that ignores custom configs? Also, is there any way to enable persistent custom settings on the server?
Thanks in advance!
Best regards,
  • I logged into the Hostinger game panel and stopped my Palworld server before making any changes to avoid overwriting issues.
  • I navigated to the path Pal/Saved/Config/WindowsServer/ in the File Manager and created a file named PalWorldSettings.ini (since it was missing), then added my custom game settings under the correct section header [ /Script/Pal.PalGameWorldSettings ].
  • I also edited GameUserSettings.ini in the same directory and added the line ServerCustomSettingsPath=PalWorldSettings to make sure the server loads the custom config file on startup.
  • After saving both files, I restarted the server — but the custom settings were not applied, and the server reverted to default values.
You edit the settings via the configuration in the settings, not by editing the INI file. You can type a setting into the top right search box to find it quickly.
