Minecraft version 1.20.2
Is it just that Windows doesn’t support showing the profiler (Did I miss reading something)?
I have tried Official server, and Fabric, they both just say that the command “tps” is not recognized. Paper seemed to install Spark on its own just fine, but the output stated that the async profiler only works on Linux.
I tried manually adding Spark to the Fabric server, and it will show in console, but not the profiler on Metrics and Status.
Not all server types support TPS monitoring. Only those that support the “tps” command which AMP runs periodically to collect the information. Some servers output the TPS in a format AMP doesn’t recognise (which would be the case if it’s provided via a plugin rather than built-in) which also prevents it from showing up.
