Configuration with Minecraft - Sleep and join message not working
Operating System Windows - Windows 11 Home on x86_64
I have set the server up so that when someone joins or pings the server while it sleeps (which it does so after 3 minutes of complete inactivity) it wakes the server. The server is not waking under these conditions, and the sleep or join message isnt working.
  • Added the messages and sleep wake
  • Stopped the server, saved the settings
  • Checked the settings are applied
  • Updated the server
  • Started the server
It’s known that sleep mode doesn’t work with playit.gg and some routers, but some have had luck by changing the wake mode from “connect” to “ping”.
If that doesn’t do anything you’ll probably just need to disable sleep mode for that instance.
