Configuration with Minecraft - Server reverts to easy difficulty and command blocks disabled
Server keeps changing certain settings in server.properties file automatically. Even when changing it back manually and restarting server the problem persists
  • Opened server.properties file
  • Located enable-command blocks=false ; changed to true
  • Located difficulty=easy ; changed to normal
  • Saved changes of server.properties file
  • Restarted server and logged into server
  • Game says command blocks are disabled on this server and game difficulty is set to easy
You need to change those settings using the web UI, since the web UI’s parameters are flushed to the server.properties file when the server starts.
You can also right click the file in the web file manager and import it
