Configuration with Minecraft - server.properties changing on startup
Virtualization QEMU_KVM
whenever i turn on the server online-mode gets enabled inside the server.properties file
  • check server.properties
  • set online-mode to false
  • turn on the server
  • check server.properties again
  • cry in a corner
All settings are done inside the panel itself. What is the reason for editing that that line in the server.properties?
If you’re using a Proxy, you need to turn off “Standalone Mode” (type “Proxy” into the search box for that instance).
