Configuration with Minecraft - Newer mincraft versions
Product AMP ‘Phobos’ v2.6.2.2 (Mainline)
Simply, there isn’t an option for newer minecraft versions that instead use a sh to launch and not a jar file. Simply it’s just looking for a jar file it will not find because the way to launch the server is via a SH file. This isn’t the case for older versions. I am simply requesting that instead of it launching via the jar I need it set to ./run.sh
  • Install any of the latest modpacks
  • Unable to change the launch from a jar to a sh file
  • Unhappy person
Just leave the jar setting on autoselect. AMP handles it automatically if you tell it the right modloader version
See the modded Java server guide in the Knowledge Base for full details
