Configuration with Minecraft - NeoForge versions have vanished from drop down list
Current State PreStart
ATM10 neoforge minecraft version went down while I was at work today. Tried to start and and it said that it couldnt find neoforge version. I investigated to find that there are no available options under the drop down for versions.
  • Server went down
  • Tried to start server
  • Server said couldnt find neoforge version
  • neoforge versions are not in the list
Same issue here, Custom modpack running latest Stable neoforge. Everything was good today it went down, gave the
“Process configuration failed. AMP wasn’t able to query the NeoForge version list. Please try again later.”
No versions list on the drop down either
Stop the instance from the main UI, then use the file manager on the left to browse to the instance and remove its NeoForgeVersionManifest.xml, then start the instance again.
Worked for me! Thank you!
I also found the note on the Discord support detailing how to switch the server to custom and just write the startup parameters to use the existing Neoforge.
But thank you, this should get my TPS monitoring back.
