Configuration with Minecraft - minecraft server motd keep disappearing after restart
Product AMP ‘Phobos’ v2.6.0.8 (Mainline)
Probably I’m doing something wrong but, every time I restart the server, even when I do literally nothing but just restart the server, my motd disappears. Sometimes It comes back alone to the default one set by the host. I never had this problem with other server hostings and I always make the same type of minecraft server so, I would apreciate any help to understand what is going on. Thank you very much.
  • Setting my personal MOTD
  • restarting the server
  • Loosing the MOTD after the restart
Did you enter it in the web UI’s settings? Because if you only did it in the server.properties, you need to right click the file and import it
I always edit the server.properties file. I did the file import right now ans you suggested, but the problem is still there.
Is it possible to get rid of all the minecraft configuation settings thing from the pannel? I never had that extra pannel to do the same thing I already can do in the files. I also can’t change anything like /whitelist on and off from the game, because after the restart all the config are getting reset to default. Having the same configuation in more places creates a lot of confusion.
Im having a lot of problems with this host on the most basic stuff because it’s just not working the way it shoud work.
Open for any kind of suggestions and tips to solve this problem. And thanks.
Note, this isn’t Hostinger support, just the forum for AMP.
There is no way to disable it no. You must use the panel to configure things, or import the file after making your edits. (there is also a search bar in the upper right for when you can’t find something)
