Configuration with Minecraft - lower render distance than set
Product AMP ‘Callisto’ v2.5.0.14 (Mainline)
I have set the render distance in the minecraft configurations to 64 chunks, and my render distance in minecraft to the maximum, however while on the server I am barely getting a 10 chunk render distance
  • Set render distance to 64
  • set in game render distance to 32
  • no improvement
Wrong setting. You need to change the setting under Server Settings.
Also you should not be setting the render distance that high, given that MC is mostly singlethgreaded, the server would just crash and die if you started exploring lol.
You can use client-mods to cache the chunks on the client, artificially increasing the render distance without impacting the server. (google it)
