Configuration with Minecraft - Jar selection resets after reboot of instance
Product AMP ‘Deimos’ v2.7.2.8 (Mainline)
GTNH updated latest stable - containerized
On instance reboot it resets the server jar to be the automatic selection which is always wrong. This makes scripting the servers updates a bit of a problem.
  • Install GTNH via the guide “Setting Up A Modded Java Minecraft Server”
  • Follow special steps for GTNH near the bottom
  • reboot instance it should now select the default Jar instead of the one you’ve selected
