| Operating System | Windows - Windows 11 Pro on x86_64 |
| Product | AMP ‘Proteus’ v2.8.0.0 (Mainline) |
| Virtualization | None |
| Application | Minecraft |
| Module | MinecraftModule |
| Running in Container | No |
| Current State | Ready |
I can’t figure out why that is. I set the RAM usage to 10 GB, but it shows that much more is being used.
I suspect that the launch flags might be affecting this somehow, because everything displayed correctly right out of the box. But I need the names
- I installed launch flags from Aikar’s Flags
- I kept toggling the display of statistics and metrics back and forth
- Maybe I set the launch flags incorrectly somehow, and now that’s causing these problems
