Configuration with Minecraft - I can't use pixelmon mod
Virtualization QEMU_KVM
Everytime I try to run pixelmon mod, the server don’t start. I’ve tryied different instances with different configurations, but it’s the same I think. I tryed ver. 1.16.5, 1.20 and 1.20.2, with their related Java ver. I suppose I don’t understand somenthing about your platform. I used to host my sorver on my local computer. Please help me.
This is the error I’ve found in console:
Exception in thread “main” java.lang.IllegalAccessError: class cpw.mods.modlauncher.SecureJarHandler (in unnamed module @0x2f4551e6) cannot access class sun.security.util.ManifestEntryVerifier (in module java.base) because module java.base does not export sun.security.util to unnamed module @0x2f4551e6
at cpw.mods.modlauncher.SecureJarHandler.lambda$static$1(SecureJarHandler.java:45)
at cpw.mods.modlauncher.api.LamdbaExceptionUtils.uncheck(LamdbaExceptionUtils.java:95)
  • Create instance
  • install forge
  • upload pixelmon mod
  • check if server is working
Make sure you’re using the right Java runtime for the version of Forge that you’re using.
And be sure that you’re uploading the mod through the web manager or SFTP, as manipulating the files directly will mess up file perms.
And as a general note, we are not Hostinger.
