Configuration with Minecraft - Filezilla Help
I just can’t seem to access the SFTP with FileZilla.
  • First I went into the site manager of FileZilla and changed the Logon type to interactive
  • I then pressed on SFTP file access in the file manager of my minecraft server and inputted the relevant addresses and ports.
  • With my username, admin, FileZilla then prompts me to connect with my password which I use to enter this panel and it does not work. I do not have 2FA setup as well.
  • And I have already tried turning off my firewall.
Make sure that you’re using the correct SFTP port, and that you haven’t accidentally selected FTP
