Configuration with Minecraft - Error with AMP
I’m getting the message: “Client-side databinding failed. If you’ve just upgraded AMP then you should first try clearing your browser cache.” and “TypeError: (intermediate value).Name is not a function”. I already took care of the caching and the amp is updated.
  • Create a new event in Schedule
  • Add 2 triggers
  • Edit the last trigger
  • Change the conditions for the trigger, like wait for the first trigger to run
It’s a known bug when adding a variable in the current version - next update has a fix. For the time being you can simply add {@Name} (or whatever the variable name is) to get the same effect.
